Networked TiVos - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-12-2008, 07:34 PM - Thread Starter
rootdr's Avatar
Hi Guys,
I use my DirecTV Sony TiVo but I am getting a TV in the bedroom I would love to be able to network them. Are there any such stand alone units I can use with Directv?
Not that bothered about HD, SD is fine.
rootdr is offline
post #2 of 4 Old 04-14-2008, 03:54 PM
bdoyledimou's Avatar
You can just get a series 2 duel tuner tivo ($50 direct from Tivo) and away you go..
I have 3 Tivo's (theater room, and two bedrooms) and have them networked, and transferring shows between them and can even stream movies from my PC to any of the devices.
PSN: Wrassle
360: Burnt of Wrassl
bdoyledimou is offline
post #3 of 4 Old 04-16-2008, 07:41 AM - Thread Starter
rootdr's Avatar
Does that mean I would have to give up my DirecTV TiVo since it's not networked? I bought the WiFi adapter for it 2 yrs ago and never used it. If I buy 2 TiVos I don't know how I would control DirecTV.
ANy ideas?
rootdr is offline
post #4 of 4 Old 05-12-2008, 11:35 AM
Beardad's Avatar
One possibly off topic Question. I have a wireless network in my home with a 6 Meg Router/Modem. I have a Linksys Hub Router I used before the router and modem were in the same box. Is there a way to hook up the HR20-700 using the Linksys Router hard wired using and Ethernet cable to the Wireless network to get the On Demand Video from DirecTv?
Beardad is offline
Reply Digital Recorders (PVRs) General
