Question about Motorola QIP6416 and Verizon - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-14-2008, 07:06 PM - Thread Starter
JMD1014's Avatar
I just got this STB today after getting an HDTV on Saturday. I bought this STB from a store nearby and hooked it up after work. It is set up properly because I am able to access the onscreen menu while the STB is turned off. However, when I turn on the STB, nothing happens and it displays nothing but a zero.
Like I said, everything else is connected fine, there just seems to be something wrong with the STB. Do I need to call and have it activated? Shouldn't they have mentioned that to me where I bought it? The subject of activation was never brought up to me.
JMD1014 is offline
post #2 of 2 Old 10-15-2008, 09:57 PM
angelinatomei's Avatar
Originally Posted by jmd1014 View Post
i just got this stb today after getting an hdtv on saturday. I bought this stb from a store nearby and hooked it up after work. It is set up properly because i am able to access the onscreen menu while the stb is turned off. However, when i turn on the stb, nothing happens and it displays nothing but a zero.
Like i said, everything else is connected fine, there just seems to be something wrong with the stb. Do i need to call and have it activated? Shouldn't they have mentioned that to me where i bought it? The subject of activation was never brought up to me.
i have been thinking about doing the same thing. I contacted the cable company and they did say you need to call for a signal after installation. Isee it has been a while. Did you ever get this to work for you?
angelinatomei is offline
Reply Digital Recorders (PVRs) General
