Suggestions for USB tuner / PCI tuner for cable? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-25-2008, 02:22 PM - Thread Starter
Henway's Avatar
Used to have a Series2 Tivo that I'd archive SpeedTV. Now with Series3 and Cablecards COX has made it impossible to transfer many channels (all above OTA).
So I'm thinking about getting a USB tuner for the computer and do it that way.
Any of you with a USB or a PCI-E card out there?
I'm guessing it's best to get one with on-board processing, but finding them is difficult. Either that or maybe find a new graphics board that also does NTSC processing?
Any suggestions?
Comments?
Henway is offline
post #2 of 2 Old 04-25-2008, 05:08 PM
demonfoo's Avatar
Quoted: 49 Post(s)
Liked: 36
Is Speed Network in digital form on your cable company's network? If so, your only option would be to get some sort of analog capture device, and connect the composite or S-Video output (and analog audio outs) from the cable receiver box to the capture device. A QAM receiver won't work, and you can't get CableCARD receiver units to work with anything other than a CableCARD-certified machine running Windows Vista.
demonfoo is offline
Reply Digital Recorders (PVRs) General
