Comcast DCH3416 video issue - AVS Forum | Home Theater Discussions And Reviews
Old 04-26-2008, 08:25 PM - Thread Starter
hevb's Avatar
We have 2 of these units, and the video on the hi def channels intermittently drops out. Audio is fine. This lasts for 2-5 seconds. comcast was out, and did not see it happen, but I did have recordings showing it. They thought it was strange. Replaced a few connectors, checked signal strength, and noise. It all seemed fine. Now they are gone and the video is still dropping out. This is only on the hi def channels.
Any ideas??
hevb is offline
Old 04-26-2008, 10:38 PM
cavu's Avatar
Did they check the signal strength at the STB?? You can do that yourself from the diagnostics menu (power off and then press "OK"). The signal strength should show "Fair" or "Good". If it is "Poor" get Comcast to fix it!
There are dropouts from time to time on the networks so if it isn't consistent, learn to grind your teeth.
"The greatest obstacle to discovery is not ignorance  it is the illusion of knowledge." - Daniel Boorstin
"Our lives begin to end the day we become silent about things that matter.
" - MLK
cavu is offline
Old 04-27-2008, 09:01 AM - Thread Starter
hevb's Avatar
Signal strength is good. The drop occurs on all hi def channels. Maybe 5-10 times during an hour period.
hevb is offline
Old 05-04-2008, 03:22 PM
stryker6040's Avatar
i just had this installed yesterday after switching from dishnetwork to comcast. i loved my dish but my neighbors tree grew in our only good line of site so we had to switch. the tech installed all new lines from the telephone pole to the house and then a new line from the ground block to the tv.
anyways i have noticed this same thing where the video will freeze up or get choppy much like it did back with dish when it would rain hard.
i also noticed that SD channels look really grainy or fuzzy, is that normal as well
stryker6040 is offline
