Comcast DCH3416 DVR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-01-2008, 08:12 AM - Thread Starter
amward1980's Avatar
I'm having the Motorola DCH3416 mailed to me from Comcast. Two questions...
1) Will the mailed DVR package contain an HDMI cable?
2) Since this is a digital only based DVR, can I record for playback standard definition cable channels such as MSNBC, Fox News, & MTV which are not being offered in HD flavors yet?
Thank you!!!
amward1980 is offline
post #2 of 6 Old 05-01-2008, 02:05 PM
demonfoo's Avatar
Quoted: 49 Post(s)
Liked: 36
You'll be able to record any channel, HD or SD. If they're issuing DCH3XXX recorders (the 3XXX models do not have analog tuners and MPEG-2 encoder chips), then they must have ADS in place. Hopefully the Moto DVR will work out for you.
demonfoo is offline
post #3 of 6 Old 05-28-2008, 11:11 AM
frlusa's Avatar
New here... just talked with the customer service gal at the Comcast office while picking up a HDMI cable... she told me that there are several customers that are hooking up their PCs via USB and downloading their DVR recordings then burning them to a DVD... I've search the internet but am unable to find anything on this topic... has anyone on this forum done this... if so, where can I find the information... thanks...
frlusa is offline
post #4 of 6 Old 05-28-2008, 08:01 PM
demonfoo's Avatar
Quoted: 49 Post(s)
Liked: 36
She's mistaken. I don't care how cute she was. The USB port on the Moto DVR is a USB type A (i.e., host) port, so you can't just cable it up to a PC (such a cable is extremely hard to find, if it exists at all), so you'd be lucky if it just did nothing. Besides, the USB port isn't even active, other than acting as a power feed.
demonfoo is offline
post #5 of 6 Old 05-29-2008, 03:24 PM
frlusa's Avatar
Figures... she wasn't even that cute... maybe the USB port will be usable someday... ...
frlusa is offline
post #6 of 6 Old 05-29-2008, 08:03 PM
merrywbee's Avatar
Hi, I just wanted to post a step by step solution for anyone who might end up searching for this online... it took me a long time to find the solution, which I found somewhere here on the board, but had to piece the steps together a bit...
How do I program the Motorola DVR box to change channels under 100, just by typing the digits, rather than always having to enter a zero in front of the digits, i.e. typing one-two for channel 12, instead of zero-one-two?
Here is the solution (for a DCH 3416 Motorola DVR box, although I suspect it works for some of their other boxes, too)
1. Press the Menu button on the DVR box, twice.
2. Scroll to SETUP and press OK/Select button on your remote.
3. Go to Guide Setup, press OK/Select button on remote
4. Go to Channel Entry Behavior and change the selection from No Auto-Tune, to Auto-Tune, using the arrows on your remote.
5. After changing it say Auto-Tune, press the OK/Select button on your remote.
merrywbee is offline
Reply Digital Recorders (PVRs) General
