Directtv HD DVR Plus - AVS Forum | Home Theater Discussions And Reviews
Old 07-09-2008, 12:28 PM - Thread Starter
scottshiv's Avatar
Can I add an external hard drive to a Directtv HD DVR Plus?
scottshiv is offline
Old 07-09-2008, 06:42 PM
demonfoo's Avatar
Quoted: 49 Post(s)
Liked: 36
You can plug in a drive via eSATA; however, the unit's internal drive will be completely unusable while the external drive is plugged in. You won't be able to access any preexisting recordings, or use that disk space in combination with the external disk. It's an all-or-nothing choice.
demonfoo is offline
Old 08-12-2008, 08:49 AM
porkozone's Avatar
If I connect an external drive to the DirectTV DVR and record something, can I later connect it to my computer and have any kind of access to the files? Does the DiretTV record in .m2t or .ts files like the Comcast DVRs do?
porkozone is offline
Old 08-12-2008, 11:08 AM
demonfoo's Avatar
Quoted: 49 Post(s)
Liked: 36
I'm sure they do like every other DVR does - they store the content in an encrypted form on the disk using a proprietary filesystem and a unit-specific key, preventing you from accessing or viewing the recordings. So no, you won't be able to pull the drive, plug it into your computer, and store those recordings for later or play them on your PC.
demonfoo is offline
Old 08-22-2008, 10:57 AM
danfoley's Avatar
is this all or something choice with the external hard drive going to change soon? That seems kinda stupid to do that..
danfoley is offline
