Copy Recorded Shows from DCT6412 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-05-2008, 12:21 PM - Thread Starter
Jimster's Avatar
It was surprisingly easy, and maybe everyone knows how now, but just in case...
First, I read all the threads about using the Firewire connection and it simply didn't work for me. Being both desperate and simple-minded, I finally simply used the Component Video outputs on the back of the DCT6412 and connected them to the component inputs on the front of my Panasonic DMR-EZ28. I played a 2-hr HD show on the DCT6412, hit the record button on the Panny and it recorded nicely, thank you very much. I was pretty impressed with the final quality, too.
The shows I've archived so far are not premium channels so they're not copy-protected. I simply run out of room on the hard drive once in awhile and need to move stuff off it onto rewritable discs in the Panny.
Having looked for a long time to figure this out (doh - head slap), I thought I'd share.
Jimster is offline
post #2 of 3 Old 09-05-2008, 02:30 PM
wajo's Avatar
Quoted: 38 Post(s)
Liked: 191
You must be referring to "Composite" Y/W/R RCA inputs and outputs since the Panny DVDR doesn't have "Component" (RGB) inputs?
If so, that's something that's always been possible with DVDRs.
wajo is offline
post #3 of 3 Old 09-06-2008, 09:42 AM - Thread Starter
Jimster's Avatar
My bad - yes, Composite. Yeah, I figured it always has been possible, but I'd never found a thread indicating that, so I thought I'd go ahead and post it just in case others were looking for the same thing. Thanks for the clarification on the cables. It jogged me to think I should probably use the S-Video input for the video.
Jimster is offline
Reply Digital Recorders (PVRs) General
