Time Warner 8300HDC diagnostic screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-07-2008, 06:03 PM - Thread Starter
stully's Avatar
So I did some searching on here and seen where it showed you how to get to the diagnostic screen by holding select on the box and when the mail LED comes up hit INFO but everytime I try this nothing happens....Ive tried this with the PVR turned off and on. Ive also tried the remote way by holding the pause button down and it says to wait till you see the mail LED but when I hold down the pause button the mail LED never appears. The reason I wanna get into the diagnostic is recently Im having big problems with my HD channels flickering and freezing for a second. Can I not see the diagnostic screen because im connected thru HDMI cable? or am I doing something wrong??
stully is offline
post #2 of 6 Old 09-08-2008, 12:46 AM
Joxer's Avatar
The method to access the diag mode varies with the cable system's software.
Its different depending on if they use SARA, Passport, Navigator for example.
Joxer is offline
post #3 of 6 Old 09-08-2008, 09:08 AM - Thread Starter
stully's Avatar
how do i figure out what software im running? then after I figure out that where would I look to find out how to access the diag mode? thanks for responding by the way, I really appreciate it
stully is offline
post #4 of 6 Old 10-06-2008, 02:21 PM
ANGEL 35's Avatar
Hit the down arrows that should work
ITS HOW YOU LOOK AT IT
ANGEL 35 is offline
post #5 of 6 Old 10-07-2008, 10:20 AM
Artificial-I's Avatar
I want to get into the diagnostic menu / service menu too? Ive got BrightHouse / TWC which I believe is using explorer or mystro.
Anyone got any idea?
Artificial-I is offline
post #6 of 6 Old 10-08-2008, 08:19 AM
ANGEL 35's Avatar
Press the select button till you see mail light up then hit the down arrowthat should do it
ANGEL 35 is offline
Reply Digital Recorders (PVRs) General
