Comcast DVR Skip Ahead/Skip Back 5 minutes - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-28-2008, 06:29 PM - Thread Starter
the q's Avatar
There looks to be a a new DVR feature that is not yet documented on the Comcast web site. The feature is a part of the new A25 guide. It works for DVR recordings and allows you to skip ahead or skip back 5 minutes at a time.The skip ahead is accessed via the page up button and the skip back is done via the page down button. This is onthe Comcast silver remote. I have a DCT 6412 and a DCT 6208 (I know, I need to get a new box) and this feature works on both of these boxes.
Does anyone else have this new skip feature?
I can reverse 15 seconds with the button on the silver remote (the instant rewind button) and I also have the 30 second skip set up as per other posts on this forum.
The 5 minutes is helpful when you want to move ahead in a movie or a longer recorded program.
I think TiVO offers a 15 minute skip ahead which is too long in my opinion.
The Q
the q is offline
post #2 of 7 Old 10-07-2008, 02:45 PM
PlatinumX's Avatar
I noticed this a week or so ago also, and not happy with it. I used the PgUp and PgDn button frequently to skip over commercial breaks, but 5 minutes is wayyyyy too long for this purpose. Of course, I can use the FF button to skip but it's not always accurate and sometimes there's a delay in playing again, whereas hitting the PgUp button a few times is just enough to get you back to the show.
I realize it's a minor gripe, but it's one of the most frequently used features of the remote. Is there a way to set it back to 30 seconds?
PlatinumX is offline
post #3 of 7 Old 10-07-2008, 05:56 PM - Thread Starter
the q's Avatar
You can still program a 30-second skip on your own to any of your remote control's buttons:
Press the “Cable” button at the top of the remote to put it into Cable Box control mode.
Press and hold the “Setup” button until the “Cable” button blinks twice.
Type in the code 994. The “Cable” button will blink twice.
Press (do not hold) the “Setup” button.
Type in the code 00173.
Press whatever button you want to map the 30-second skip command to (ex: A / Lock). The “Cable” button will blink twice if successful.
That way you will have multiple ways to skip ahead.
The Q
the q is offline
post #4 of 7 Old 10-20-2008, 06:08 PM
billr's Avatar
OK - I programmed my remote to skip forward but chose the wrong button. Now I can't move around using the > key. How do I un-program it?
I feel a little dumb.
Bill
billr is offline
post #5 of 7 Old 10-20-2008, 06:21 PM
walk's Avatar
You'll have to reset it probably. Full instructions here
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR
walk is offline
post #6 of 7 Old 02-06-2009, 02:23 PM
mlang46's Avatar
How do yo set up the 30 second skip forward I know about the 15 seconds back but I use the fast forward button 4 times whciby the way gives me a headache
mlang46 is offline
post #7 of 7 Old 02-06-2009, 02:26 PM
mlang46's Avatar
Press the Cable button at the top of the remote to put it into Cable Box control mode.
Press and hold the Setup button until the Cable button blinks twice.
Type in the code 994. The Cable button will blink twice.
Press (do not hold) the Setup button.
Press whatever button you want to map the 30-second skip command to (ex: A / Lock). The Cable button will blink twice if successful.
Thank you thank you thank you
mlang46 is offline
Reply Digital Recorders (PVRs) General
