Digital VCR Replacement... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-19-2008, 03:38 PM - Thread Starter
ghoniba's Avatar
Hi Gang:
Is there a digital, maybe a hard disc based recorder, that can be used as a VCR replacement? I am looking for something that does not require a subscription and is as easy or easier to use than a VCR for my mum. She is using basic cable.
Any suggestions would be appreciated.
Thank you, Glenn
ghoniba is offline
post #2 of 3 Old 10-20-2008, 01:55 AM
Joxer's Avatar
The closest device nowadays would be a low cost DVD recorder with a cable-ready tuner, they replaced VCRs.
Joxer is offline
post #3 of 3 Old 10-20-2008, 04:37 AM
Rammitinski's Avatar
Seeing that you're in Canada, there are a few HDD/DVD recorders with hard drives and NTSC tuners that you can get up there. The Pioneers are considered the best. Sony makes a model which is actually made by Pioneer and is a lot cheaper.
In the US there are the Philips 3576H and the Magnavox H2160, which both have NTSC/ATSC/QAM tuners. I believe they sell the Philips up there, also (at least they did the 3575H, I think). Check out the "DVD Recorders" forum here for more info.
Rammitinski is offline
Reply Digital Recorders (PVRs) General
