RF Modulator? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-12-2008, 05:20 PM - Thread Starter
Polish Pounder's Avatar
Not sure this is the right place but I am desperate.
This is my problem. I recieved a new DVR from Directv and it does not have a coax out to tv. The old one did.
Called DTV and the said I needed a modulator. Have no Idea what they are talking about and they said I can get it at any Estore.
I need it to hook up the coax to the RC jacks (yellow and white)on the DVR.
I hope that is clear as mud.
HELP!! My wife is pissed at me because I am pissed..
Polish Pounder is offline
post #2 of 7 Old 11-12-2008, 05:29 PM
ctdish's Avatar
Quoted: 67 Post(s)
Liked: 35
Providing model Nos. of receiver would be helpful. DirecTV is suggesting something like this http://www.amazon.com/RadioShack-Vid.../dp/B000VNVNP2 This kind of thing is not for HDTV and is only useful for SD TV (regular old TV). If you have VCR often they will have a video input. Hook up to that and you can use the VCR's modulator.
John
ctdish is offline
post #3 of 7 Old 11-12-2008, 05:31 PM
Ken H's Avatar
http://www.radioshack.com/product/in...ductId=2103095
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #4 of 7 Old 11-12-2008, 05:35 PM
jjeff's Avatar
Quoted: 690 Post(s)
Liked: 246
Sounds like your TV doesn't have a video type input? and your new DVR doesn't have a built in RF modulator(less and less devices do).
RF modulators accept the video output of devices like your DVR and convert it to channel 3 or 4 that your TV can tune to.
They should cost ~$20 and I believe places like Walmart or Radio Shack for sure, should carry them.
Another hokey way to get a RF modulator is to use a old VCR. They all used to have RF modulators built in. Connect your DVR video output to the line input of a VCR. Select line input on the VCR, hook RF out of the VCR to your TV and you should be in business.
Like I said kind of hokey and bulky but it is an option. Note to watch your DVR the VCR would have to be turned on.
Looks like Ken's link to RS shows RF mods. have went up since I last looked.
jjeff is offline
post #5 of 7 Old 11-12-2008, 05:52 PM - Thread Starter
Thanks Guys. I am off to Wally world or Radio Shack
post #6 of 7 Old 11-12-2008, 06:35 PM - Thread Starter
OK, I found an old VCR.
It has a Video out and audio out. these are yellow and white RC jacks. It also has uhf/vhf in and tv out coaxial. That's it.
My DVR has Sat in 1 and 2 coaxial. Also Yellow and white RC jacks.
I tired to hook this up per your directions and I can't get a signal.
My tv is across the room from the dvr. I ran the coax through the wall from the tv when I built the house. I have another coax at the dvr that is the satellite coax.
I guess i could just run component cable across my kitchen.
post #7 of 7 Old 11-12-2008, 07:13 PM
jjeff's Avatar
Quoted: 690 Post(s)
Liked: 246
You'll want to take the yellow video out and audio out of your DVR and hook those to the video input of your VCR(maybe labeled line input). Then hook the RF output(maybe labeled to TV) and hook that to your wall jack that goes to your TV.
Finally to watch your DVR you'll need to power up your VCR and select line input. Then make sure your VCRs RF modulator is on. Usually by pushing the TV/VCR button, you want it to say VCR. Then tune your TV to to whatever channel you've setup your VCR output to(either channel 3 or 4).
Should work fine but definitely not the best picture quality or probably not stereo. Your component connection would be better but not as practical in your case.
jjeff is offline
Reply Digital Recorders (PVRs) General
