DCH6416 Remote Control Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-16-2008, 09:17 AM - Thread Starter
wa2joc's Avatar
Is it possible to have two DCH6416 receivers side by side with the individual remotes set to a different code so that both receivers do not respond to both remote controls at the same time?
If not, are there any workarounds or other options?
I would like to switch from Directv to my local cable company but my setup requires the two boxes to be in same area.
Thanks for any responses,
Bill
wa2joc is offline
post #2 of 3 Old 11-16-2008, 12:07 PM
rjfranken's Avatar
in a multi reciever environment (sports bar) the trick I use is to attach (or hold) a opaque tube of some sort to over the front of the remotes LED. choking the light it rifles the signal to the unit it is pointed at and the others cannot see the signal.
rjfranken is offline
post #3 of 3 Old 11-18-2008, 05:05 PM - Thread Starter
wa2joc's Avatar
Thanks for the suggestion.
wa2joc is offline
Reply Digital Recorders (PVRs) General
