DCH3416 not talking with AVCVideoCap 1.06 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 01-02-2009, 03:56 PM - Thread Starter
QuasiKoz's Avatar
Hi Everyone,
I haven't had this problem before, but all of a sudden AVC Video Cap 1.06 from Apple's FireWire SDK 26 is no longer "talking" with my Motorola DCH-3416 cable box.
I'm wondering if anyone else is having this problem. Is it...
- an AVC Video Cap problem? Do we have to wait for SDK 27?
- was there a firmware update for the DCH-3416 that would cause a problem?
I double checked my connections and powered down/up the DCH-3416. Still nada. Any help would be appreciated.
QuasiKoz is offline
post #2 of 26 Old 01-10-2009, 04:55 AM
GameDayDog's Avatar
I don't have a solution, but I wanted to let you know that you are not alone.
I have a Mac PowerBook G4 and a Motorola DCH3416 with Comcast Cable in Florida. I was recording shows both live and from my DVR. But I just tried it today and AVCVideoCap is not working.
I'm not sure what the previous firmware for the DCH3416 was ... but going thru the setup it is now - 18.43.
I disconnected everything as well with no avail... I also reprogrammed my the DCH3416 to broadcast in 480i again, because I changed the settings to 1080i after I purchased my television. That didn't help, either.
It's definitely comcast trying to control us... I can't wait for another fellow genius to crack it.
Peace..~G
GameDayDog is offline
post #3 of 26 Old 01-12-2009, 06:40 AM
HTH
HTH's Avatar
I have noticed that AVCVideoCap's "Defer Record Start Until" function does not have a setting for 2009. The year field initializes to a blank value and choices are only 2005, 2006, 2007, and 2008. Leaving the field blank causes it to complain that the "[s]pecified record start time is in the past". Non-deferred recordings still work for me. It clearly requires an update or patch.
I've never gotten FireRecord (nee iRecord) to work with my SA Explorer 3250HD.
HTH is offline
post #4 of 26 Old 01-12-2009, 11:44 PM
HTH
HTH's Avatar
Figured out that I needed to download the SDK 26 before I could modify the Xcode project (the SDK 25 project would beachball indeterminably). Some changes to year handling have to be made to AVCVideoCapController.mm (r/2004/2008/, r/2010/2014/, and r/2005/2009/) and to English.lproj/MainMenu.nib's Window1 object to display the new year range correctly (now 2009 to 2012 in my build).
I'm not seeing an easy way to redefine the values in the combobox without editing the MainMenu.nib with Interface Builder. I could change them to read "This year", "Next year", "In two years", and "In three years", enlarging the combobox and redefining the base year at startup simply enough, but it's not as neat as just displaying the year. Plus you'd need to know what year you started it in. Why not just let me type in the year with the pre-filled presumption of this year?
I also made some (unnecessary) changes to the MainMenu object in MainMenu.nib so it says AVCVideoCap instead of NewApplication under the AVCVideoCap and Help menus (it just bugged me).
I may yet patch the "Specified record start time is in the past!" error to just record anyway and treat any passed start time as already elapsed recording time. If I'm one second late for starting the recording, I'd hate to miss the whole first minute!
HTH is offline
post #5 of 26 Old 02-03-2009, 07:24 AM
hondo21's Avatar
Two things -
1. I don't know if your problem with the moto box talking to AVC Video Cap 1.06 is the same problem everyone is having with DVR recordings, but that is the result of a broken firmware update, see discussion here:
http://www.avsforum.com/avs-vb/showthread.php?t=1032148
For me, it works fine for "live" recordings straight to the box. But DVR recordings (or running straight from the box after it has been paused, which is similar to using a DVR recording since it comes from the hard drive) are problematic. There is a workaround which sometimes works but often there is no audio PID and thus you get no sound. Supposedly there is a firmware fix for this, but who knows when Comcast will implement it, if ever.
2. I just ran into the "defer recording start" time issue for the Super Bowl. I normally don't use this feature so I didn't know there was an issue with the year choices running out at 2008. But I was leaving home about an hour before the Super Bowl and wanted to defer a direct recording until gametime and found that I couldn't because of this. I tried to see if a newer version of the program was out there, but it wasn't (that I could tell). So I had to record that extra hour before the game (couldn't just use a DVR recording because of the problem in #1 above).
I don't know anything about using the SDK tools to modify and build the program as you are describing. I'm kind of an Apple newbie who hasn't done any programming stuff. If you or somebody could provide a step-by-step tutorial for dummies (like me) on how to do that I'd appreciate it. Or, if there's a way to just download a modified version somehow that would be okay too.
hondo21 is offline
post #6 of 26 Old 02-26-2009, 07:55 PM
swbuehler's Avatar
I've noticed with the project that it starts the recording before it does a channel change. How can this be modified so it does the channel change, pauses a second or two for the channel change to take, then start recording? I'm not a C person.
swbuehler is offline
post #7 of 26 Old 02-26-2009, 08:03 PM
swbuehler's Avatar
I figured it out myself... there's a usleep(1000000) further down that needed to be changed from 1 to 3 (3 seconds) to allow the channel change.
post #8 of 26 Old 03-11-2009, 05:25 PM
brooklodyte's Avatar
Could you (or anyone else) please post a link to this fixed build? I don't know anything about software development, xcode, or interface builder... I just want to schedule recordings in 2009. It sounds like an easy fix, but it's still all over my head. Thanks.
brooklodyte is offline
post #9 of 26 Old 03-25-2009, 05:13 PM
HTH
HTH's Avatar
I expect it to be a bit popular and I'm not sure if I can handle the bandwidth for hosting it on my own domain. I could maybe do a torrent, but I've never set up one before. How do I choose and register with a tracker?
HTH is offline
post #10 of 26 Old 04-07-2009, 08:34 AM
koltron's Avatar
@ HTH
which part of the .mm file are you're referencing with 'r/2004/2009'
I follow everything you say except I cannot locate the year handler in AVCVideoCapController.mm
do I need to add these llines are modify existing code?
thanks
-koltron
koltron is offline
post #11 of 26 Old 04-07-2009, 08:53 AM
koltron's Avatar
@HTH
sorry for the post and message, I figured it out. I was confused on the notations
koltron is offline
post #12 of 26 Old 04-07-2009, 09:39 AM
HTH
HTH's Avatar
Originally Posted by koltron View Post
@HTH
I should have ended it with a "g" to indicate "global".
For others who might still be confused, r/xxxx/yyyy/g means (r)eplace instances of xxxx with yyyy (g)lobally (i.e. throughout the file).
HTH is offline
post #13 of 26 Old 10-10-2009, 09:16 PM
HTH
HTH's Avatar
I've done some more tinkering, first replacing deprecated classes with current ones (except for cString and stringWithCString as I haven't found the supported equivalents (though it does use fopen which takes char * and doesn't complain about it)) to re-familiarize myself with the code, and then decided I really hated the pop-up boxes for the date and time (scrolling through minutes 00 to 59, really?) and how it would yell at you for specifying a start date in the past. So I put two NSDatePickers in instead for start and end times, got rid of the "Recording Time in Minutes" and made it treat a start time in the past as an immediate recording (won't work if you run this before Midnight January 1, 2001 GMT, time travelers and clock fidgeters) eliminating the need for the "Defer..." check button.
Bonus: you can specify recordings down to the second (great for padding start and end by 30 seconds), have them span years without converting to minutes first, and not requiring updates every four years to enable new date ranges.
Drawback: start and end are initially equal. I apparently need to use dateWithTimeIntervalSinceReferenceDate to convert from NSTimeInterval back to NSDate. It also needs some general preferences for certain constants like default duration, rounding start to next minute/15/30/hour, with or without n seconds lead/tail.
I think I'll add a field for that too, though I know it doesn't work with my SciAtl box. That's something else that should be a preference setting so you don't have to remember every time.
I'm working on finding a host for the newly patched application. According to the original code, I can distribute it.
HTH is offline
post #14 of 26 Old 11-09-2009, 09:26 AM
HTH
HTH's Avatar
HTH is offline
post #15 of 26 Old 11-18-2009, 06:50 PM
IHateScreenNames's Avatar
Have you found anywhere to post your updated avcvideocap app? I sure could use it right about now
IHateScreenNames is offline
post #16 of 26 Old 12-27-2009, 12:52 PM
craiginsd's Avatar
I believe I could use HTH's modified version as well, but I'm now getting a failure to even allow "Capture From Device". Not sure if this is the date range issue, or something else. Eternal gratitude to whover can steer me in the right direction.
Also tried iRecord, FireRecord, and Capture Magic, but NONE of these record nor preview the DV stream from my Cox SA8300HD.
I REALLY need to clear off some space from the DVR, so help is needed soon!
craiginsd is offline
post #17 of 26 Old 03-26-2010, 03:07 PM
leejacs's Avatar
Hi
so i have been playing around for this for a while, trying to get the date problem (ie year 2004 - 2009) to read 2009 - 2012 (at least to get 2010 so i can do some scheduled recording).
i have edited the files as above in HTH post - (cheers) but i can only find the files in the example folders - editing these dose not make any difference.
help - please - love to show my PC mates how cool this is
leejacs is offline
post #18 of 26 Old 04-01-2010, 01:42 PM
leejacs's Avatar
well, if anyone is interested here my fixed (for the date problem) executable.
AVSVideoCapp.app
leejacs is offline
post #19 of 26 Old 04-01-2010, 03:44 PM
qz3fwd's Avatar
Quoted: 297 Post(s)
Liked: 124
I dont think my DVR lists DV, DV is the wrong format. That may be your problem. Try pulling the power plug on your DVR and rebooting. (Not power off/power on buttons)
qz3fwd is offline
post #20 of 26 Old 04-24-2010, 03:32 PM
HTH
HTH's Avatar
OK, I'm going to try to attach my version to this posting. It doesn't have the user-settable delay for the channel changing included yet as I've been busy.
I have found that having the AM/PM at the end of the date choice is a bit cumbersome when setting up an afternoon recording in the morning. Neither control will allow you to set a date-time in the past and are initially set to the moment the window came up. If in fact the start time has fallen to the past, it will treat the start as "now".
I have had some problems recently with the capture aborting after only a few minutes. As I have made no changes to the software to account for this recent development, I can only assume it's the cable company doing things with my box (it's been turning itself off at inopportune times lately).
Update: turns out the capture aborts were due to the UPS to which the cable box was connected failing.
AVCVideoCap.zip 430.3037109375k . file
HTH is offline
post #21 of 26 Old 04-25-2010, 07:28 PM
qz3fwd's Avatar
Quoted: 297 Post(s)
Liked: 124
thanks for your version.
can I ask if you compiled this on snow leopard with xcode and if you had to change any project settings? when I tried compiling it I got errors in MusicSubunitController?
qz3fwd is offline
post #22 of 26 Old 04-25-2010, 08:53 PM
HTH
HTH's Avatar
Let's see... Snow Leopard was released on August 28, 2009, my binary is dated Feb 20, 2010, so yeah, I think so. However it is targeted for 10.5 | Deployment | i386. Are you building for 10.6 directly?
I did have to change a few things to stop using deprecated structures so I could use the new date picker (NSDate and NSTimeInterval). I don't have any references to MusicSubunitController in my version.
I need to run a diff to refresh myself on my changes.
Correction: Feb 20, 2010 is when I added the icon, but I did do a rebuild under Snow Leopard and it worked. IIRC I could not get it to build for 10.4 under Xcode under Snow Leopard.
HTH is offline
post #23 of 26 Old 11-03-2011, 12:11 PM
HTH
HTH's Avatar
I'd really like to feature-up the program a bit more. I want to be able to use iCal to trigger AppleScripts to control AVCVideoCap, but I don't know where to look to learn how to add scriptability to an application. Lacking this is why I haven't used it much lately, though I find I'm needing to use it to record The Office tonight.
And I need to get that usleep patch in there too, and test it under Lion.
HTH is offline
post #24 of 26 Old 06-14-2012, 09:01 PM
Nate Radmacher's Avatar
Has anyone tried this in Lion yet?
This is my first time using the application. I open it up, and with my device highlighted, I click "Capture From Device"... However, it only brings up a save dialogue box but the "Save" button is disabled (as pictured).
163
I have 40GB of space available on my hard drive. Can anyone help me out??
Nate Radmacher is offline
post #25 of 26 Old 06-14-2012, 10:30 PM
OK... well (dumb!) I realized I just needed to name the file that I would be saving.
So, unfortunately, the show I wanted to record is "Copy once" protected. Is there ANYWAY to get around this (with any sort of device or software - Mac or PC) while still maintaining the HD quality (i.e. not S-video or RCA cables)??
post #26 of 26 Old 10-29-2012, 11:07 PM
ralnraln's Avatar
Hey Guys,
I can record live from a channel no problem, but when I try to capture a recorded show on my Motorola DVR (DCT 3412 Phase III) using AVCVideoCap it doesn't record or playback properly..
Any help??
ralnraln is offline
Reply Digital Recorders (PVRs) General
taboola here
