Scientific Atlantic Explorer 8240HDC - How do I set Audio out? - AVS Forum | Home Theater Discussions And Reviews
Old 01-11-2009, 04:13 PM - Thread Starter
SoonerAJ's Avatar
I currently have my 8240 connected through component cables to my TV. Everything is working well except I'm getting a lot of buzz on the speakers of the TV and I wanted to switch to an HDMI connection. When I connect through HDMI, I get picture but no sound. I've read that I need to change the audio out to HDMI. I'm not even sure how to find the menu for these options. How do I get to the audio setup on the 8240HDC?
Thx
AJ
SoonerAJ is offline
Old 01-12-2009, 06:53 AM
bd1
bd1's Avatar
press SETTINGS twice to get to general settings menu, select digital audio out, change from dolby to HDMI, then select & exit & you should be ok.
bd1 is offline
Old 01-12-2009, 06:14 PM - Thread Starter
SoonerAJ's Avatar
Thx bd1! That worked for me. Now my sound is coming through HDMI.
SoonerAJ is offline
Old 02-15-2009, 05:38 PM
craigalancarter's Avatar
Thanks for posting the question, I had the same issue; but now I have a new problem to solve. I have the HDMI cable going for the cable box (Explorer 8240) to the AVR (Marantz 5003), I'm getting audio through the speakers, but the sound is popping on and off, it appears to occur during scene changes on the TV...very annoying. How do stop this?
craigalancarter is offline
Old 02-25-2009, 08:39 PM
tall turtle's Avatar
Thank you bd1 for the answer to the sound problem. It worked for me also.
tall turtle is offline
