Philips 3576 questioin - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-24-2009, 07:39 AM - Thread Starter
tomf52's Avatar
Have one of the above named units and the cooling fan runs almost all of the time. Is this as it should be or do I have a problem with it? Even when the recorder is off the fan will run. Air coming out of the fan is also very warm.
tomf52 is offline
post #2 of 3 Old 01-24-2009, 09:52 AM
tmwalsh0's Avatar
If the air is warm, it is dumping heat that would otherwise eventually affect the componentry, no? It may have a 'standby' setting so the HD is not spinning 24X7, or could have 'sleep' mode. I tried to get one, but didn't offer enough dough on the web auction.. waaahhhh...
I think you would get more response in the area that is all about DVDRs. This one is about Tivo and Dish type recorders. (I think, I am not that experienced here...)
This should get you there: [DVD Recorders - AVS Forum]
http://www.avsforum.com/avs-vb/forum...ysprune=&f=106
tom
tmwalsh0 is offline
post #3 of 3 Old 01-24-2009, 11:35 PM - Thread Starter
tomf52's Avatar
Thank you for the help. Will repost there.
tomf52 is offline
Reply Digital Recorders (PVRs) General
