HDD drive for FTA receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-28-2009, 06:51 PM - Thread Starter
ivtec's Avatar
Have FTA receiver with pvr function supported, that says record/play with a external HDD,my question is there any special HDD that i should get to work with this type of fta receiver?thanks in advance.
ivtec is offline
post #2 of 4 Old 03-01-2009, 10:24 AM
demonfoo's Avatar
Quoted: 49 Post(s)
Liked: 36
Erm, what country specifically are you in? What unit are you dealing with? I'm not aware of such a unit for the USA, so I'm guessing you're probably elsewhere.
demonfoo is offline
post #3 of 4 Old 03-01-2009, 12:24 PM - Thread Starter
ivtec's Avatar
Thanks for you help, I'm in USA have FTA HD Nfusion Nunenio,
ivtec is offline
post #4 of 4 Old 03-02-2009, 08:27 AM
demonfoo's Avatar
Quoted: 49 Post(s)
Liked: 36
It seems to be the "Nfusion Nuvenio"; searching doesn't seem to indicate any special drive requirements, but it does sound like it uses a FAT32 file system, so you may (not sure) need to format it as FAT32 before plugging it into the unit. Check the documentation.
demonfoo is offline
Reply Digital Recorders (PVRs) General
