Copying from DVR to PC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-15-2009, 08:19 PM - Thread Starter
bkersh's Avatar
I've been reading through numerous threads and haven't found a definitive answer (maybe just missed it)
I have a motorola dhs3416 from comcast and all i would like to do is to copy some of the recorded programs from the dvr to my computer. I dont care if they are in hd i just want to be able to view them and ultimately burn a dvd.
there is a fire wire connection, a usb connection, AV connections, hdmi connections all that i could use.
does anyone out there have a definitive answer whether this can be done??
bkersh is offline
post #2 of 4 Old 03-16-2009, 05:57 AM
Liked: 644
Firewire is an option, but it's probably easiest to hook up a DVD recorder to the composite outputs and do manual records of what you want to keep.
slowbiscuit is offline
post #3 of 4 Old 03-21-2009, 03:25 PM
lexicon RX7's Avatar
Direct tv DVR Question?
When I record a Program with my dvr,now i want to record to a disk.
What do i need to do this.Would Appretiate any help.
( If this is not the best forum for this question,could someone direct me
THANKS
lexicon RX7 is offline
post #4 of 4 Old 03-25-2009, 03:48 AM
CruisinG35's Avatar
I think what you are looking for is the Hauppauge 1212 PVR. It can capture 720p/1080i from your cable box. As far as I know, it's the only device out there that can do what you describe.
CruisinG35 is offline
Reply Digital Recorders (PVRs) General
