Help for Device Driver for Motorola DCH-3416 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-17-2009, 04:28 PM - Thread Starter
dhan1972's Avatar
Hello,
I have this Motorola DCH-3416 from Comcast. I am trying to access this to my computer using FireWire Cable but the driver could not be found. I searched in many sites, could not find. Spoke with Comcaset tech support still not. Anyone have anyidea where to get the Device Driver for Motorola DCH-3416 AV/C Tuner/Panel. I have VISTA OS.
Dhan
dhan1972 is offline
post #2 of 3 Old 07-06-2009, 02:51 PM
virexix's Avatar
Hello. I am trying to do the same thing as you are and I am having the same problem.
When Vista was looking for the drivers, it found two devices:
MOTOROLA DCH-3416 AV/C Tuner
MOTOROLA DCH-3416 AV/C Panel
It wanted me to insert a disc, which I didn't have. Then it told me there was no way to install the driver. Comcast says the ports are disabled, but they aren't. Motorola does not have any drivers.
Anyone else looking for this or have the same problem? Thanks.
I found this link: [urlmn]http://www.pcpitstop.com/drivers/download/Motorola~AV%252FC~Tuner~Device~%28DCH-3416%29.html[/urlmn]
I don't know if it will help though.
virexix is offline
post #3 of 3 Old 07-06-2009, 02:53 PM
virexix's Avatar
Here I just found a link:
[urlmn]http://home.comcast.net/~exdeus/stbfirewire/[/urlmn]
virexix is offline
Reply Digital Recorders (PVRs) General
