8300HDC Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-19-2009, 07:49 PM - Thread Starter
slumdog's Avatar
Hi, I have a (probably dumb) question:
I have Time Warner Cable and went in earlier today and picked up a Scientific Atlantic 8300HDC box. I don't yet have an HDTV, but am planning on buying one within the next couple of months. I figured that I would be able to use it on my old standard def TV in the meantime, but it doesn't appear to be working. Do these only work with HDTV's? Any help would be greatly appreciated. Thanks in advance!
slumdog is offline
post #2 of 3 Old 03-19-2009, 09:19 PM
DefinitelyJoe's Avatar
Yes, they work fine for std tv. Does box display time?
DefinitelyJoe is offline
post #3 of 3 Old 03-19-2009, 11:10 PM - Thread Starter
slumdog's Avatar
Nevermind, fixed it! Thanks for replying
slumdog is offline
Reply Digital Recorders (PVRs) General
