Is this vertical banding ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-26-2009, 06:01 PM - Thread Starter
Mr.Cinema's Avatar
I have a Panny AX200 great great pic ....
The unit has bout 6 months of use on it .Turn it on today to watch College Basketball notice a green stripe on the right side of my screen.. I change the channel same results, change hdmi cable same results .. I have the unit hook up to my comcast hdtv box .... I only get the green stripe when I'm watching TV i have unplug my cable and replug it back in same results .. What could be causing this ?? Thanks for any and all help
Mr.Cinema
Mr.Cinema is offline
post #2 of 3 Old 03-26-2009, 07:41 PM - Thread Starter
Mr.Cinema's Avatar
I figure out the problem it was the cable box .. had to go into service menu and change the output signal ...
post #3 of 3 Old 03-31-2009, 11:54 PM
Jetame's Avatar
yes right may be the cable box have some problem you should check it patiently
and if you can't resolve it you should ask the engineer
A man dies still If he has done nothing ,as one who has done much
lost 1-4 dvd||smallville 1-7dvd
Jetame is offline
Reply Digital Recorders (PVRs) General
