Sa 8300 pvr... - AVS Forum | Home Theater Discussions And Reviews
Old 04-25-2009, 05:56 AM - Thread Starter
Joelc's Avatar
I have a Scientific Atlanta HD8300 PVR and neeed to know whether the HDMI output transmits a DD 5.1 input signal as:
a) DD 5.1 bitstream
b) DD 5.1 PCM
c) DD 2.0 bitstream
d) DD 2.0 PCM
Thanks in advance...
Joel
Some people choose to have a pool, I choose to have a home theater!
Joelc is offline
Old 04-25-2009, 01:17 PM
bfdtv's Avatar
DD5.1 bitstream is the default, but if you connect HDMI directly to your display, the SA DVR will send PCM 2.0 if your display requests it over EDID.
bfdtv is offline
Old 04-25-2009, 04:41 PM - Thread Starter
Joelc's Avatar
Appreciate that...confirmed this by testing a direct connection between the SA 8300 and my Meridian 861 pre/pro...seems as though the EDID commands in my RadianceXE are a little flakie...
Thanks so much...
Joel
Joelc is offline
