DirecTV DVR Recorded show not playable - AVS Forum | Home Theater Discussions And Reviews
Old 05-21-2009, 10:12 AM - Thread Starter
ShaggyDoug's Avatar
I'm running into an occasional problem on my DirecTV DVR when recording HD shows off of the local Fox Affiliate. It is recording and if I happen to switch to the channel during the recording time, I see the show in HD on the TV. I don't always switch to the show to see whether or not it is displayable or not. I'm saying that I do know the signal is there and watchable on some of the times I've tried to make sure that the show was being recorded. However, when I go to playback the show from the beginning the next day, I immediately get a gray screen and the "Would you like to delete this recording or save it" choice box (I can't remember exact wording on that dialog) like it was at the end of the program.
I have the HD-DVR - HR20-700 model. The show in question is in HD. I generally set the series recording to start a few minutes before and then end 2 or 5 minutes later.
So a few questions:
1. Anyone know what's going on?
2. Anyone know a way to get these shows viewable again? My family is quite irate about the jacked up recording of American Idol last night.
- shaggy
ShaggyDoug is offline
Old 05-21-2009, 10:39 AM
Stew4msu's Avatar
I've seen it happen occasionally.
Most of the time a RBR (or reset) of the receiver fixes it and the show will play. Sometimes it's just lost. Not sure why it happens, but I've only lost 1 or 2 shows in the last six months.
Stew4msu is offline
Old 05-25-2009, 10:07 AM
John Robert's Avatar
I had this happen many times with the same DirecTV DVR, including some periods where it did it to every show recorded. The shows appear on the list but you get only the delete screen on playback. After multiple resets and chats with a CSR, the problem mysteriously disappeared when my box was updated. Are you plugged into a phone line?
John
"What happens in Vegas..."
John Robert is offline
