DirecTV DVR - No HDMI? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-25-2009, 10:14 AM - Thread Starter
John Robert's Avatar
I was going to change my DVR over to a HDMI connection as opposed to my current component/coax digital set-up since it would be easier conceal the cord from the box to my Integra 9.8 pre/pro. However, even with the HDMI cable connected, I can't select "1080p" in the resolution menu even though it cautions "HDMI cable required". Am I missing something simple?
John
"What happens in Vegas..."
John Robert is offline
post #2 of 3 Old 05-25-2009, 10:39 AM
bfdtv's Avatar
No cable or satellite DVR exists with 1080p60 output. The 1080p option is used to output 1080p24 on HD VOD/PPV. If your display/receiver doesn't "advertise" that it supports 1080p24 over HDMI (EDID), then you won't be able to select that option.
bfdtv is offline
post #3 of 3 Old 05-25-2009, 10:49 AM - Thread Starter
Thanks for your reply. I'm running the signal thru an Integra 9.8 pre/pro to a Mits HC6500 projector. I'll research the EDID support for each as I think they do 1080p24 over HDMI but I know just enough to be dangerous :-)
John
Reply Digital Recorders (PVRs) General
