Explorer HD8300 install taking a long time - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-27-2009, 03:28 PM - Thread Starter
Bigred22's Avatar
I just upgraded from the IO box to the HDTV Explorer 8300...
I got it all set up but where the clock is supposed to be it has H and in to the left of it is constantly changing numbers which I assume means its installing but its been going on for almost an hour already.
The book says it take several minutes, so how long can I expected to wait for this?
Bigred22 is offline
post #2 of 2 Old 05-27-2009, 05:03 PM
demonfoo's Avatar
Quoted: 49 Post(s)
Liked: 36
It's probably searching for a boot server, and failing to find one. Is the coax cable plugged into it? Is it in the right port? Are there any intervening splitters? Maybe just try unplugging it for 5 minutes, and plugging it back in again. If it's still looping like that, that's the most likely scenario. If after unplugging it, removing any intervening splitters, making sure the coax is attached securely and plugged into the right port, etc. it's still failing, try calling the cable company and see if they're having any ongoing issues.
demonfoo is offline
Reply Digital Recorders (PVRs) General
