FIOS Home Media DVR / 7216 - quick Q's - AVS Forum | Home Theater Discussions And Reviews
Old 05-28-2009, 04:52 AM - Thread Starter
AbMagFab's Avatar
I'm going over to help a friend with this, and I have some quick questions (I use Tivo, so want to understand better):
1) Main question: How do you "connect" from an HD/SD slave box to the Home Media DVR?
2) Can you watch live TV on each of the slave boxes without using a connection to the Home Media DVR?
3) How many tuners does the Home Media DVR have?
4) Can you upgrade the HDD, or add an external drive to it?
5) Can you only watch HD DVR programs on the HD slave boxes, or will it downconvert to the SD slave boxes?
6) I'm pretty sure you can only set up recordings directly from the Home Media DVR, and not from any of the slave boxes?
7) Is the photo/music app worth it? Can you do photos/music to any of the slave boxes as well, or just the Home Media DVR directly?
8) Anything else I should be aware of or concerned about?
Thanks in advance for any advice!
TiVo is on it's way out - stream everything!
AbMagFab is offline
Old 05-28-2009, 12:34 PM
bfdtv's Avatar
Verizon uses the Actiontec router to create a 100Mbps network over the existing coax cable in your home. Television uses frequencies 0-860MHz on the coax and the 100Mbps network uses frequencies above that.
Yes. The "slave" boxes are Motorola QIP2500 (SD) and QIP6200/QIP7100 (HD) set-top boxes. They can be used with or without MRDVR service.
Two.
No. You are limited to ~20 HD hours.
Verizon plans to offer more storage/capacity options before the end of year.
You can only watch HD recordings on the HD boxes. You can only watch SD recordings on the SD boxes.
That is correct. There is no way to schedule or delete recordings using the SD and HD STBs.
Pictures are only accessible on the DVR. As for what it's worth running software on a PC, that depends on the person.
The multi-room DVR is the same as the standard DVR, but with extra software features enabled.
The QIP7216 DVR may offer slightly better SD output quality than the older QIP6416 DVR. Both models will periodically "forget" how much free space is available. This is a known issue; to"fix" it, is unplug the box for 30 seconds.
bfdtv is offline
Old 05-28-2009, 04:34 PM - Thread Starter
AbMagFab's Avatar
Thanks so much!
AbMagFab is offline
taboola here
