Can I transfer videos to PC from Motorola DCH 3416 DVR? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-14-2009, 11:13 AM - Thread Starter
nosoupforu's Avatar
I want to transfer video from my DVR to my PC? Is this possible or is Tivo the only one who can do this?
I have a Motorola DCH 3416 DVR
If not, can I buy some sort of HD TV card for my PC and record shows directly to my PC with HD quality?
nosoupforu is offline
post #2 of 4 Old 07-14-2009, 06:50 PM
11001011's Avatar
No and sort of... Tivo is the only one that allows network transfers of recorded programs.
TV tuner cards are limited to clear QAM channels since they have no cablecard support. Most cable companies have or are in the process of limiting clear QAM channels to only channels that are in their "limited basic" tier.
There are a few very expensive PC TV tuner devices that have cablecard support. But by the time you add up the cost of the tuner and a PC powerful enough to record full HD, you would be spending more money than buying a Tivo-HD with a lifetime subscription.
A 'phile and his money are soon parted...
11001011 is offline
post #3 of 4 Old 07-29-2009, 12:47 PM
jsirbak's Avatar
Are you sure? I have a Motorola DCT-6412 cable box and download videos off of the box onto my PC all the time using the firewire port. It can be cumbersome since the transfer is done at 1x speed (it take two hours to download a two hour movie off of the DVR), but I'm getting full HD resolution transport stream files onto my PC. I'd be surprised if there wasn't a similar work-around for most cable boxes.
jsirbak is offline
post #4 of 4 Old 07-31-2009, 10:30 AM
bfdtv's Avatar
With the Motorola DVR and Firewire, you are copying shows as they are played. You aren't "downloading" shows. Furthermore, this only works on unencrypted channels (i.e. local HD channels); the Motorola DVR encrypts Firewire output for encrypted channels, as well as unencrypted channels marked with the broadcast flag.
TiVo is the only cable DVR that actually allows you to actually download the shows. You can queue up multiple shows for download, and you can set your favorite series to automatically download whenever your computer is on. A few screenshots:
Download shows using a standard web browser.
Download shows using the free TiVo Desktop software.
Download shows, automatically remove commercials, and re-encode for an iPod/iPhone using the free, Java-based kmttg program.
Note some providers, most notably Brighthouse and Time Warner, severely restrict what you can download.
bfdtv is offline
Reply Digital Recorders (PVRs) General
