SA 8300HD can it be set to 480i widescreen - AVS Forum | Home Theater Discussions And Reviews
Old 07-28-2009, 09:45 AM - Thread Starter
EVT
EVT's Avatar
Quoted: 46 Post(s)
Liked: 25
Hi guys,
Is it possible for the SA8300HD to output 480i widescreen for SD and 1080i for HD with a single setting (i.e. passthrough) so I don't have to fumble around with the aspect controls on the TV or PVR?
EVT is offline
Old 07-28-2009, 05:57 PM
Monger's Avatar
Liked: 66
Originally Posted by EVT View Post
Hi guys,
Sure. Turn the dvr off, hold select and info until the menu pops up. Follow the instructions from there to select 1080i and 480i standard. After you turn the dvr back on select passthrough from the menu.
Monger is offline
Old 07-28-2009, 07:11 PM - Thread Starter
EVT
EVT's Avatar
Quoted: 46 Post(s)
Liked: 25
However, I realize that you can do this with 480i standard but I would like to use 480i widescreen instead as it maintains the proper aspect ratio on a widescreen TV when the TV is set to full.
EVT is offline
Old 08-04-2009, 09:42 AM
chroma601's Avatar
I have written to Scientific Atlanta several times, asking about adding a menu control to switch the archive out (Record to vcr) to anamorphic. Archiving a HD program results in a horrible postage stamp SD recording, but if the output could be switched to anamorphic then it would be worthwhile.
They never answered, of course.
Aibohphobia: The fear of palindromes
chroma601 is offline
Old 01-23-2010, 08:45 AM
8196357's Avatar
when you select 480i standard on your scientific atlantic box, your tv will do the stretching, and thus you do not need to use the Aspect button on your remote any more, it will fill in the entire image area of your widescreen lcd.
480i Widescreen mode, is almost never used for broadcast, except the channel DW, which is 195 on my rogers cable box, it broadcasts in 480i/p widescreen. thus its the only channel i know of that uses that mode, for all others, they show grey bars on the sides.
8196357 is offline
