Vip 722 missing the end of shows - AVS Forum | Home Theater Discussions And Reviews
Old 10-07-2009, 09:56 PM - Thread Starter
JediSpork's Avatar
Quite often the end of a show is missed with my vip 722 on a variety of stations. When it was first installed the box was setup to record about a minute late and several minutes before a program started. This worked ok for a while but we ended up with to many conflicts that way.
Is there some kind of problem with dish networks clock or does it have to do with the tv stations themselves? This is a very annoying problem especially after how much the service costs and we end up missing the end of shows.
JediSpork is offline
Old 10-09-2009, 04:12 PM
Straybeat's Avatar
I have wondered this exact thing myself. Our 722 was fine for the last couple years until seemingly an update a couple months ago. We also had the automatic timer extension where programs started 1 minute early and ran 3 minutes past the end time. Now it's gone. Both times have reset to zero. If I set them manually the DVR ignores the time and still shuts off early OR if I record 2 shows in a row the last 3 minutes of the first show is on the beginning of the second show. The second show then shuts off before the end. Talk about annoying and frustrating!
Straybeat is offline
Old 10-13-2009, 02:35 AM
Lij
Lij's Avatar
Location: Hill Country bordering the Lower Wabash Valley of Indiana
I have a new 722 as of September and mine is doing fine. Sometimes shows run over or start late.... that's why the gods made TV Guide I guess.
If you changed the timing on one show, the 722 then asks if you want that 'timer'/timing event to cover only that show or all shows. Could it be that you changed one show, chose to to have it cover all shows and now all are cutting off the end? Or could it be the internal clock gets messed up - I haven't figured out just how that is set?
I noted that if you choose to record two programs back-to-back that are on the same channel then the unit automatically sets the end to be at '0' and also the start to be at '0' from the GUIDE's idea of when a show starts and stops (that doesn't work if they are on different channels). I've noticed that is sometimes about 15 seconds before what I know to be the top of an hour. But some shows are now having content run to that last possible moment in their time-slot and sometimes I get the end on the beginning of the next show.
As to a show that is not followed by a another recording event, I always use the 'Option' menu (I think that is it) after I create the timer to adjust the start and end times and make that ending time is about 2-3 minutes later than stated end time. So if a show ends at 5 minutes after the hour, I set the timer to end 7 or 8 minutes later than what DISH's Guide would record. I don't trust the Guide most times, and so far, I haven't missed anything.
Without music, life would be an error... if music be the food of love, play on.
My Audio/Video Configuration
Lij is offline
