CCI Byte filter - AVS Forum
post #1 of 10 Old 10-29-2009, 06:45 PM - Thread Starter
Stormspace's Avatar
I don't post here often, so I don't really know where to ask this question...
Is there a way to filter the Digital CCI Byte from a cable broadcast so my TiVo will be able to use MRV?
Stormspace is offline
post #2 of 10 Old 10-30-2009, 05:19 AM
bicker1's Avatar
No, and any means of doing so would be illegal, as it would effectively defeat an asset protection mechanism.
bicker1 is offline
post #3 of 10 Old 10-30-2009, 10:18 PM
Yakuman's Avatar
Use a second tuner and run it into the line-in on the DVR.
Yakuman is offline
post #4 of 10 Old 10-31-2009, 09:39 AM
demonfoo's Avatar
If his TiVo is new enough to actually know about the CCI byte (which means it's a Series3 or TiVo HD), it has no line-in, making this moot.
demonfoo is offline
post #5 of 10 Old 10-31-2009, 11:48 AM
bfdtv's Avatar
Modern TiVos like the TivoHD do not have line-ins. They have two built-in tuners and that's it.
bfdtv is offline
post #6 of 10 Old 11-03-2009, 10:31 AM - Thread Starter
Stormspace's Avatar
I was just wondering if there was any line filtering equipment that removed the CCI Byte info from the cable stream.
@Bicker
I believe I'd be protected since MRV doesn't currently work for any channels on my DVR and I'd only be using it to access those channels I can legally transfer.
post #7 of 10 Old 11-03-2009, 02:54 PM
bicker1's Avatar
Such a thing would be illegal.
That is not the case. The laws against defeating copy protection mechanisms make no provisions for violating the law in cases where the mechanism was engaged in error, assuming it was in error.
As it is, remember that your cable or satellite service provider is explicitly permitted to apply the CCI byte to any channels it wishes except for local OTA broadcast channels.
bicker1 is offline
post #8 of 10 Old 02-13-2010, 05:06 PM - Thread Starter
Stormspace's Avatar
Apparently removing the cable cards also remove the CCI byte. And that's not illegal.
post #9 of 10 Old 02-14-2010, 09:55 AM
Liked: 148
Duh, and it also removes access to the channels you're paying for. What's your point?
slowbiscuit is offline
post #10 of 10 Old 03-03-2010, 10:14 AM
alokkola's Avatar
I ran into the CCI byte issue with my TivoHD. The one channel I want to record locked down by the 0x03 CCI byte so it deletes the recording after 90 minutes.
As per TivoHD...
0×03 – Copy Never – the content can be recorded and viewed for 90 minutes after transmission, and is not transferable. Content disappears from the Now Playing list after 90 minutes.
Does anyone know if I would run into the same issue if I switched to Moxi? I don't know their DRMs.
alokkola is offline
Reply Digital Recorders (PVRs) General
User Tag List
