Scientific Atlanta Dvr on cablevision(Ny) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-15-2009, 03:38 AM - Thread Starter
thelonerangers's Avatar
I got the 8300 SD Dvr, I might be getting a HdTv so i gotta upgrade to the Hd Dvr. But I want all stuff I go on this dvr, is there any way without just opening up the box, to extract the files to my computer. Any ideas would be great, I got some movies that are rare. Thanks in advance.
thelonerangers is offline
post #2 of 7 Old 11-15-2009, 08:25 AM
bfdtv's Avatar
You can't transfer or offload recordings from the DVR, nor can you open the box and extract the files (they're encrypted). The best you can do is use an analog capture card on your PC.
bfdtv is offline
post #3 of 7 Old 11-15-2009, 01:11 PM - Thread Starter
What do you mean by that? If theres a cable input on my video card?
post #4 of 7 Old 11-15-2009, 02:27 PM
bfdtv's Avatar
Normally, you might have a composite video input or a breakout cable with a composite video (or s-video) input.
bfdtv is offline
post #5 of 7 Old 11-15-2009, 02:35 PM - Thread Starter
yea but i would have to use the audio input also to record the audio correct?
post #6 of 7 Old 11-15-2009, 03:18 PM
bfdtv's Avatar
Yes.
bfdtv is offline
post #7 of 7 Old 12-14-2009, 06:59 PM
Rich_Lanz's Avatar
the lone ranger:
you can copy the recorded movies. It is a bit involved, tho, and remember they are digitally protected are only playable in another DVR, not say on your computer.
The SA boxes format the disks in a Linux format.
So to do it you have to remove the HD from the DVR ( without damaging the "void" sticker on the inside, attach the drive to a computer running Linux and copy the files. You then copy them back to the new HD and replace it in the new DVR.
Do a google search for - cloning internal HD SA8300 and you will find the instructions on the Rogers Cable forum
Rich
Rich_Lanz is offline
Reply Digital Recorders (PVRs) General
