HD Service with an HR10-250 with DirectV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-30-2009, 06:25 PM - Thread Starter
Neil154's Avatar
If I upgrade to HD service with DirectV but keep my HR10-250, can anyone tell me what the issues are? I know that the HR10-250 does not support the latest encryption technology but I like it. What channels will I not be able to get at all what channels will I not be able to get in HD? Are there any other issues that I need to consider?
Thanks for your help.
Neil154 is offline
post #2 of 4 Old 12-01-2009, 02:54 AM
bfdtv's Avatar
DirecTV now uses MPEG-4 for its HD channels. The HR10-250 (released in 2004) doesn't support MPEG-4, and therefore doesn't support DirecTV's HD channels. If activated with DirecTV, it supports HD locals from an off-air antenna, but that's about it.
If you want a HDTV DVR for DirecTV, you need to get the HR2x with DirecTV's own DVR software. DirecTV also plans to offer a new HDTV DVR with the TiVo software, but that is some months off.
bfdtv is offline
post #3 of 4 Old 12-03-2009, 05:50 PM
Ralarcon's Avatar
Quoted: 126 Post(s)
Liked: 111
What is this doing in this HD DVD forum ? Re direct please. Thanks.
Ralarcon is offline
post #4 of 4 Old 12-23-2009, 01:46 PM
DiscoDuck's Avatar
Quoted: 14 Post(s)
I switched out my hr10-250 only because it couldnt pick up the locals in HD over sat and as I remember it also wouldnt pick up the premium movie channels, also mp4 format. I loved the tivo cause it could record the local channels OTA via antenna, but the signal was sometime weak.
Sr7009 + external amp for 9.3.4
jbl - northridge x11; sp6cii ceiling
Dayton HF15 sealed x2 on xls1500
av123 mfw15 w/ bash 300
DiscoDuck is offline
Reply Digital Recorders (PVRs) General
