Linksys WGA600N and SMC Powerline - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 12-15-2009, 07:51 AM - Thread Starter
ispy1009's Avatar
I am trying to connect both a Directv HR20 and an LG BD370 blu-ray to my home network and onto the Internet. I am using the WGA600N for the LG and the SMC Powerline adapters for the Directv. I can only get one or the other connected. Each works fine with either the HR20 or the LG, but when one is connected to the Internet the other wont. Is it possible to have both work at the same time? Last night I called Directv and the tech walked me through setting up the HR20. As soon as it was connected to the Internet, I turned on the LG and when I attempted to connect to Netflix I got the not connected error message. Then I disconnected the HR20 and sure enough I was then able to connect to Netflix with the LG. Of course I don't need to have both running online at the same time as they are both connected to the same tv, but I would like to have them both up and running so that I can switch between the two without having to reconfigure every time. Any thoughts?
ispy1009 is offline
Reply Digital Recorders (PVRs) General
