Scientific Atlanta PVR 8300HD - how to open the case? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-20-2009, 06:48 AM - Thread Starter
bobafart's Avatar
Hi there my hard drive either crashed or needs to be reformatted
in order to get to it i need to crack the case on my 8300HD PVR (warranty is over)
there are small screws on the back but not fit for a screw driver
can someone tell me how to open the case on the 8300HD pvr? the manual doesnt help and neither does a google search
thanks!
bobafart is offline
post #2 of 2 Old 12-20-2009, 07:08 AM
Digiti's Avatar
thanks!
You probably need a TORX screwdriver.
Digiti is offline
Reply Digital Recorders (PVRs) General
