Did the Dish 722 loose a tuner??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-27-2009, 01:13 AM - Thread Starter
Sundance's Avatar
Did the 722 loose the OTA tuner when it became a 722k? I just dumped cable and re-signed up with Dish. I'm sure I remember my 722 a year and a half ago having an OTA tuner. The new 722K I was delivered today it appears does not have a OTA tuner. There is no Ant. in ( that was the first clue) and when you go to the menu where you would scan channels, it is disabled (grayed out).
I was right the 722 did have the OTA tuner and the 722k does not. But $30 for the tuner isn't to bad.
Has the 722k been de-featured in any other ways?
Sundance is offline
post #2 of 6 Old 12-27-2009, 10:15 AM
bfdtv's Avatar
The ViP722K is a design refresh based on the same next-generation CPU found in the upcoming ViP922. It dropped the single, built-in OTA tuner and added a slot for a dual-tuner OTA module.
With the $30-$40 OTA module, the ViP722K can record two satellite channels and two OTA channels simultaneously.
No. With the OTA module, the ViP722K is superior to the ViP722 in every way. In fact, the ViP722K is essentially a ViP922 without the beta software and Slingbox encoder. It's more responsive and has the CPU necessary to support Dish Network's next-generation HD UI, something the original ViP722 cannot do.
bfdtv is offline
post #3 of 6 Old 12-27-2009, 11:41 AM - Thread Starter
Sundance's Avatar
Another question about the 722k. When I add an external USD hard drive is it like the old 722 in that it was simply storage space, you had to move content from the internal drive to the external drive. Or can you record to the external drive and use it in the say way the internal drive is used with the 722k?
Sundance is offline
post #4 of 6 Old 12-27-2009, 11:52 AM
bfdtv's Avatar
External storage works the same way it did on the ViP722. The ViP722K uses the same basic software, updated to support a fourth tuner (2 OTA, 2 satellite).
bfdtv is offline
post #5 of 6 Old 12-27-2009, 02:43 PM - Thread Starter
Sundance's Avatar
I seem to have found something that contradicts that. Not saying you are wrong, I don't know but this seems to say otherwise. What do you think?
If you go to prefs > Record Plus > ERD Setup there is an option that states "Enable recordings to an external device". Doesn't that sound like you can record to the external device? Is it either external or internal and not the two, as if they were one big drive?
Sundance is offline
post #6 of 6 Old 12-27-2009, 05:59 PM
bfdtv's Avatar
From what I recall, Dish Network uses EHD to refer to external drives and ERD to refer to the PocketDISH mobile video player.
I haven't used a Dish Network satellite DVR in months, so I can't say for certain whether the external storage support is as you remember. My recollection is that recordings had to be moved manually. I can say for certain that the external storage options on the ViP622, ViP722, and ViP722K are identical.
bfdtv is offline
Reply Digital Recorders (PVRs) General
