Problem with Dish 622 - AVS Forum | Home Theater Discussions And Reviews
Old 12-29-2009, 03:41 AM - Thread Starter
Leesrt's Avatar
Last night my Vizio stopped receiving signal from my 622 via hdmi. Its connected directly as is my xbox.
I switched inputs at the tv and the xbox works fine in all inputs. I did the same with 622 and it doesn't work in any.
Then I reset the 622 by pulling the card and plugging back in and after the 622 booted back up the picture came and and then in a couple minutes cut off again.
Anyone ever experience this?
Leesrt is offline
Old 12-30-2009, 12:46 AM - Thread Starter
Leesrt's Avatar
I did a little research and found this is a common problem with the 622. It started in 2006 and they still haven't fixed it. I would suggest that if your getting a dual tuner dish hd dvr go with the 722 at a minimum. It doesn't seem to have the same problem.
Leesrt is offline
Old 12-31-2009, 06:59 AM
Margi's Avatar
Last night our picture went out too. I didnt know if it was the onkyo or the 622. Thanks to your post, I will start with the 622.
Margi is offline
