why do i need 2 cables in a dvr to record 2 shows - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-18-2010, 08:17 PM - Thread Starter
mattff's Avatar
why do i need 2 cables in a dvr to record 2 shows. couldnt there be more tuners in the box.
mattff is offline
post #2 of 8 Old 02-19-2010, 07:07 AM
demonfoo's Avatar
Quoted: 49 Post(s)
Liked: 36
Every DVR I'm aware of now splits inputs internally, making multiple physical cable inputs unnecessary. What DVR specifically are you referring to here?
demonfoo is offline
post #3 of 8 Old 02-19-2010, 12:36 PM - Thread Starter
mattff's Avatar
why did the makers not use one cable from the beginning. All they had to do was splice the cable in the box and use the two tuners that are already in there.
mattff is offline
post #4 of 8 Old 02-19-2010, 02:15 PM
demonfoo's Avatar
Quoted: 49 Post(s)
Liked: 36
Again, what DVR are you referring to here? Unless you can mention a specific model, no one's going to know what the heck you're on about here.
demonfoo is offline
post #5 of 8 Old 02-19-2010, 04:22 PM - Thread Starter
mattff's Avatar
direct tv r16-300 which is new within a year and a tivo hughes hdvr2 from 2001
mattff is offline
post #6 of 8 Old 03-22-2010, 06:25 PM
RussB's Avatar
Location: Houston, Texas Comcast SA 8300HD DVRs Guide S25 Phase 1 with Patch
Here is a link
that says for this satellite dish and DVR, two cables are required:
http://74.125.47.132/search?q=cache:...&ct=clnk&gl=us
One posts says:
"You can't use a splitter to turn the one cable into two, you need a separate cable all the way to the dish or multiswitch."
RussB is offline
post #7 of 8 Old 03-25-2010, 09:12 PM
11001011's Avatar
A satellite dual tuner DVR needs two cables because it's two complete satellite receiving systems all the way from the two tuners to the dual LNB on the dish.
This is because two different channels could be on two different transponders and even two different satellites.
A 'phile and his money are soon parted...
11001011 is offline
post #8 of 8 Old 04-21-2010, 07:43 AM
snowman stl's Avatar
Without physically turning the dish you won't be getting a different satellite than your pointed at. But you're right, each sat has multiple transponders and multiple channels per transponder.
snowman stl is offline
Reply Digital Recorders (PVRs) General
