Question about Tivo and QAM channels - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-21-2010, 10:41 PM - Thread Starter
hyedipin's Avatar
Quoted: 62 Post(s)
I understand that Tivo does not allow any way to manually map channels or tell adjust its guide to match QAM channels for viewers who subscribe to cable but does not use cable box or cable card.
What I read was that we could not use season pass, search, etc.. features but can record using Record button. Does that also prevent scheduled recording a.k.a. VCR-like recording, where I tell it to record channel 42.2 for 1 hour at 4:00pm on certain date? Can't it at least do that?
I am planning to return my DVR to time warner, pick up a TiVo off ebay with lifetime subscription for about $200 and use that, but I would like to be able to schedule recording on those QAM channels, especially when even HD versions of regular broadcast channels are in different places than where they should be (Fox 5 HD on 93, CW11 HD on 119, etc..) The TiVo would be series 2 SD box, but I assume it can still tune to those HD channels but display them in SD?
KDL52W4100
Yamaha RX-A550, 17 year old Sony speakers
Roku, Fire TV, Viewsat Receiver, Time Warner NYC, Harmony 700
hyedipin is offline
post #2 of 5 Old 02-22-2010, 01:16 AM
TedSeattle's Avatar
Quoted: 86 Post(s)
Liked: 201
HD channels are encoded in a completely different manner than SD channels, and the analog tuner in a Series 2 box won't be able to display them. If you buy a converter box (the ones subsidized by the government to ease the DTV transition), you should be able to get the regular SD channels over the air. I'm pretty sure they won't work with cable, though.
TedSeattle is online now
post #3 of 5 Old 02-22-2010, 10:11 AM - Thread Starter
hyedipin's Avatar
Quoted: 62 Post(s)
Hi Ted.
Thanks for your answer.
The channels would be coming from Time Warner cable. You mean Tivo can't display digital channels either?
KDL52W4100
hyedipin is offline
post #4 of 5 Old 02-22-2010, 11:52 AM
TedSeattle's Avatar
Quoted: 86 Post(s)
Liked: 201
A Series 2 Tivo, no. You will need a Tivo HD.
post #5 of 5 Old 02-22-2010, 06:44 PM - Thread Starter
hyedipin's Avatar
Quoted: 62 Post(s)
Well that changes my whole plan now. Thanks again.
KDL52W4100
hyedipin is offline
Reply Digital Recorders (PVRs) General
