Hauppauge HD PVR - AVS Forum
post #1 of 2 Old 02-28-2010, 12:46 AM - Thread Starter
0odama's Avatar
Im having problems ive tried using it on two laptops and my home computer. i hook up the component cables for my ps3 to the hauppauge and it appears on my computer/laptop. is there any way to use my tv to play/record. also on my computers the video is lagging so i cant even play my games on it because of that. what should i do?
0odama is offline
post #2 of 2 Old 03-01-2010, 04:38 AM
bfdtv's Avatar
The newest version of the Hauppauge software allows you to disable the video window to significantly reduce CPU usage. Have you got that?
bfdtv is offline
Reply Digital Recorders (PVRs) General
User Tag List
