Are Motorola STB-DCT700 and DCT3416 CableCard? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-10-2010, 02:29 PM - Thread Starter
enb141's Avatar
Hi guys I'm wondering if those Set Top Boxes use CableCard or what they use?
enb141 is offline
post #2 of 4 Old 03-11-2010, 08:56 AM
demonfoo's Avatar
Quoted: 49 Post(s)
Liked: 36
They do not use CableCARD; none of the DCT-series devices do. Only DCH-series Moto cable STBs do. If you are (as I suspect) considering buying one on eBay instead of renting from your cable MSO, they still won't accept a DCH-series box, as they're not on the CableCARD certified devices list (because they're intended for sale/installation directly by the MSO, not by an end user).
Edit: As for what they do use, they use integrated security services, which were restricted with the advent of the FCC's July 2007 CableCARD mandate.
demonfoo is offline
post #3 of 4 Old 03-12-2010, 11:53 PM - Thread Starter
enb141's Avatar
So in other words those devices are prohibited in the US?
enb141 is offline
post #4 of 4 Old 03-14-2010, 11:22 AM
demonfoo's Avatar
Quoted: 49 Post(s)
Liked: 36
Not prohibited, because the cablecos themselves use them, but if you have one that you acquired by any means other than renting it from your MSO, they're not going to touch it with a ten foot pole. If you seriously suggest you want to use it, expect a response along the lines of someone watching as your face turns inside out.
demonfoo is offline
Reply Digital Recorders (PVRs) General
