Anyone know how to recover the data from - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-14-2010, 03:45 PM - Thread Starter
ccla's Avatar
A motorola dvr 6412 Hard drive that's been removed from the case? I have a co-worker who lost a lost of stuff in Katrina and basically now owns this DVR. Cox has written it off and he removed the hard drive. I can see a few partitions using linux but they all show up as unallocated space. If anyone has done this please holler at me with some info. Thanks
ccla is offline
post #2 of 3 Old 04-28-2010, 11:03 AM
zaphodnl's Avatar
There are number of tools to recover the partitions, directories and files from a damaged disc. Here are a couple I've used, more or less successfully:
1. PC Inspector: http://www.pcinspector.de/Default.htm?language=1
Used it for a disc where the partition structure had been overlaid, and no structure could be found by Windows or Linux. Pretty good tool, but will find a lot of files where parts are damaged. But it did recover a couple of files I really wanted.
2. iolo Search and Recover: http://www.iolo.com/sr/5/
Same here, use the trial version first, before you shell out the money. Turned out it didn't work in my case.
/Henrik
zaphodnl is offline
post #3 of 3 Old 05-02-2010, 11:46 AM
demonfoo's Avatar
Quoted: 49 Post(s)
Liked: 36
The video on the drive will be encrypted anyway, so unless you just happen to have a supercomputer in your back pocket to crack the encryption layer, your time will be wasted (not to mention that the Motorolas do not use a known standard filesystem, so you'd be rooting through raw data blocks anyway).
demonfoo is offline
Reply Digital Recorders (PVRs) General
