I would like a hdtv tuner card - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-04-2010, 06:52 PM - Thread Starter
marketpantry's Avatar
Im in north america and would like a hdtv tuner card so i can record shows onto a hard drive. ideally id like one new or used for 50.
edit:i can spend 50 now
marketpantry is offline
post #2 of 9 Old 05-05-2010, 05:05 AM
bicker1's Avatar
You can find some used HDTV tuner cards at eBay for about that price.
bicker1 is offline
post #3 of 9 Old 05-05-2010, 08:14 PM - Thread Starter
tuner cards plug into a different slot than a graphics card correct?
post #4 of 9 Old 05-05-2010, 11:28 PM
Joxer's Avatar
ATI has some models with a graphics card combined with an HD tuner plus PVR software, then you only need one card/slot for it all.
Joxer is offline
post #5 of 9 Old 05-06-2010, 08:37 PM - Thread Starter
i already have a graphics card. im just wondering if tuner cards go in separate slots. my guess is from your post they do?
post #6 of 9 Old 05-07-2010, 06:14 AM
bicker1's Avatar
Most tuner cards I've had were PCMIA cards.
bicker1 is offline
post #7 of 9 Old 05-07-2010, 09:28 PM - Thread Starter
which means what? I want something that goes into the motherboard and thast i can connect my cable to.
post #8 of 9 Old 05-08-2010, 03:17 AM
bicker1's Avatar
There are some that work that way as well... I'm just saying that my experience (and therefore the more detailed help I can give) is limited to PCMIA cards.
bicker1 is offline
post #9 of 9 Old 05-08-2010, 06:49 PM - Thread Starter
oh ok. where can i go to get reviews of both internal and external?
Reply Digital Recorders (PVRs) General
