Motorola DCH-3416 digital audio - AVS Forum
post #1 of 3 Old 05-13-2010, 11:54 AM - Thread Starter
BigT2's Avatar
Can I get 5.1 sound from the coax digital audio connection or only from the optical connection?
Tom
BigT2 is offline
post #2 of 3 Old 05-17-2010, 04:46 AM
lizrussspike's Avatar
Tom
Yes,
I believe that you have to go into the menu options and select Dolby Digital under the audio out options. i am not aat my DCH presently, but I get Dolby Digital reading on my Pioneer having it connected with optical cable in the TV/SAT input. I will look back to exactly what I had to do, but that is pretty much what I remeber, so yes you can!
Marantz SR7008
Emotiva XPA5
PS3
PSA XV15se
Sony BDP-370
Toshiba HD-A2
Polk Monitor 70's,Polk CS20,Polk R50's,Polk F/XiA4's,Polk OWM3's
Polk PSW 505's
Sharp 60 LED 640U
Optoma HD25-LV
Belkin PureAV Home Theater Power Console
lizrussspike is offline
post #3 of 3 Old 05-17-2010, 12:33 PM - Thread Starter
BigT2's Avatar
I have no problem with the optical cable but I can't get it through the coax digital.
Tom
BigT2 is offline
Reply Digital Recorders (PVRs) General
User Tag List
