SA 8300HD / external HDD program corruption after AC fail - AVS Forum
post #1 of 3 Old 08-22-2010, 04:51 PM - Thread Starter
Siffleu's Avatar
Hi
I have a SA 8300 HD with known compatible external HDD. I've plug my PVR + external HDD to a UPS.
here is symptom, sometime when I try to play a program I came back to the default screen that ask "press list" or exit. That happened when my hdd was not plugged into the ups. From what I have understand it's because the HDD boot AFTER the PVR so it lost it's connectivity.
Now, everything is plug into the UPS and I decided to reboot my pvr since it been a while.
I have turn off pvr, remove power cord, wait few second, turn off external hdd, wait few second, power up the hdd, wait about 10 seconds, and power up the pvr.
my program list was there but I wasn't able to play ANY program
then I've tried also to boot without external hdd, same problems
another boot with hdd plugged and same problems
had to reformat everything...
did I did something wrong ?
Siffleu is offline
post #2 of 3 Old 09-10-2010, 04:24 PM - Thread Starter
Siffleu's Avatar
anyone ?
Siffleu is offline
post #3 of 3 Old 09-10-2010, 05:11 PM
Speedskater's Avatar
Most of the information on SA 8300HD and external hard-drives is in the "HDTV Recorders Forum"
http://www.avsforum.com/avs-vb/forum...sprune=30&f=42
Kevin
Speedskater is offline
Reply Digital Recorders (PVRs) General
User Tag List
