2 Motorola DCT6412 Cable boxes need to control them seperatly in the same room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-07-2010, 10:04 AM - Thread Starter
cecilmx6's Avatar
I have 2 Motorola DCT6412 III stacked on top of each other in a rack and can not figure out how to change the channel independently without switching one of the boxes off. Is there a way to setup 1 of the remote controls to a different IR channel so it doesn't change both boxes? Is there any sort of RF remote control that can switch between the two?
Thanks for any help in advance.
cecilmx6 is offline
post #2 of 2 Old 10-25-2010, 08:38 AM
doc_chiron's Avatar
Greetings: I know what you are after, but all Motorola-based STBs use the same infra-red remote code as do all of the Scientific Atlanta STBs.
I get around that limitation by controlling my STBs via their IEEE1394 interfaces. By connecting them to my HDTV that is similarly equipped with IEEE1394 interfaces. I know these interfaces are falling out of favor on newer HDTVs, but HTPCs can control them as well using appropriate software.
doc_chiron is offline
Reply Digital Recorders (PVRs) General
