DirecTV HR24 Can't access external drives - AVS Forum
Old 12-17-2010, 11:31 AM - Thread Starter
joelhe's Avatar
Correction: After a full reset of the HR24, I was able to get the new WD drive working. Unfortunately, I lost all the recordings on the old drive because, as I learned, a full reset changes the encryption code that links the DVR to a specific drive. The content is still on the old drive but it is not accessible.
I've had a 1 TB external hard drive on my HR24 working since September. The generic eSata enclosure has always caused electrical noise(AC Hum) on AM radios in my house so I purchased a Western Digital My Book AV DVR Expander 1 TB USB 2.0/eSATA Desktop External Hard Drive WDBABT0010HBK-NESN* to replace the old drive.
When I followed DirecTV's instructions for adding the new drive, the unit would not recognize the drive and defaulted to the internal drive. After several tries I gave up and hooked up the old drive which it now won't recognize. Tried again several times following the instructions carefully. No joy. Cannot access any of my recordings.
As a last resort, I disconnected the old external drive and did a full system reset on the DVR, wiping our the internal drive. I then tried hooking up the old external again. The DVR still will not recognize it.
Help please, my wife is really going to be pissed when I tell her we lost all the recordings.
Thanks in advance, Joel
*Note: When I checked the box on the WD drive, it says it is compatible with HR15, 20, 21, 22 and 23 - no mention of HR24. Kind of strange since the WD drive is a new model and it does not appear to work with DirecTV's latest receiver.
joelhe is offline
Old 12-19-2010, 06:29 AM
coytee's Avatar
Liked: 122
I use a BlacX docking bay withg a 2TB drive. It's worked great for me and I can swap drives as well has having zero fan noise!
coytee is offline
Old 03-20-2011, 08:37 PM
H( . Y . )TeRs's Avatar
Sorry to bump an old thread but what external hd can I use for the hr24-100?
tia
H( . Y . )TeRs is offline
Old 04-04-2011, 07:19 AM
upsupsdog's Avatar
Works well but the drive light is always lit up and never seems to power down.
Anyone see this issue ? Thanks
upsupsdog is offline
Old 04-22-2011, 04:33 PM
srfrdan's Avatar
tia
im sure weaknees.com has one
srfrdan is offline
Old 04-22-2011, 04:37 PM
srfrdan's Avatar
did u remember to start the esata at least 30 secs before u restart ur receiver
srfrdan is offline
User Tag List
