AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Digital Recorders (PVRs) General (http://www.avsforum.com/forum/100-digital-recorders-pvrs-general/)
-   -   Directv Error Message 771 (http://www.avsforum.com/forum/100-digital-recorders-pvrs-general/1318408-directv-error-message-771-a.html)
jakebank 02-28-2011 05:39 AM
If there are any DTV gurus out there, I'm in need of some help. I recently moved into an apartment that is prewired for Directv. I had Directv previously, so I simply just wanted to plug in and go. The dish they have on the roof is a Slimline 5, so I set my receivers to use that at the dish. I have one D12 regular receiver that works just fine. The other receiver is a HR23 HD-DVR, and I keep getting the 771 message when watching TV. About 2-3 times every minute or so it comes and goes. On the wall in the living room is a single port to run my coax from, which I run to splitter, then into the back of my receiver. I think maybe the splitter is causing this to happen? If it is the splitter how do I get two lines ran to the back of my receiver since I cannot simply run the lines myself? Directv will charge me to come out as I've already called them, with no help. Anyone that can chime in would be appreciated as this is driving me crazy! Thanks.
R8ders2K 04-15-2011 11:34 PM
When you moved to you take advantage of D*'s Movers Connection program?
As they would have set you up and made sure everything was working.
srfrdan 04-22-2011 03:30 PM
hi in case u havent resolved ur problem u need 2 cables to ur dvr and one to ur d12. to do this u need a multi-switch. however most ms's need 4 cables into them. so u may only be able to hook up ur dvr to use its two tuners. also u can set ur dvr to use one tuner and then u can use the d12 too. theres no way to use a splitter.theres the new single wire multi switch satelite antennna system thats been out for only one year. doubtful ur apartments got it but u can ask ur landlord. if he can run another line to ur apartment that would fix it to. u have to have a separate line to each tuner. on the new system they combine the four inputs into one line with one ms and decombine them at ur machines with another ms. dan
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
