Hauppauge HD PVR IR Blaster and Directv H21-200 - AVS Forum | Home Theater Discussions And Reviews
Old 08-19-2011, 09:34 PM - Thread Starter
DrGerm's Avatar
I have an HTPC with a Hauppage HD PVR connected with the included IR blaster attached to a Directv H21-200 (HD Receiver).
I configured the blastcfg program by using the learning feature for using the Directv remote.
When using Windows Media Center, however, I can't change the channels appropriately. I am quite sure it has something to do with the settings in blastcfg (Blaster Configuration), but just can't figure this out
Any ideas what to put into the following settings?
1. Min. Digits to Send
2. Inter-Digit Delay (ms)
3. Power On Delay (ms)
4. Key Delay (ms)
5. Tuning Delay (ms)
6. Single Digit Delay (ms)
7. Send 'Power On' before Channel [Yes or No]
8. Send 'Enter' after Channel [Yes or No]
9. Use Major Minor Channel Format [Yes or No]
Thanks for any help!
"As you know, you build a home theater in the room your wife gives you, not in the room you might want or wish to have at a later time"
DrGerm is offline
Old 09-17-2012, 01:58 PM
jgarizona's Avatar
Did you ever get this to work? I have the same setup.
jgarizona is offline
taboola here
