explorer 8300hd problem ...help please! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-30-2011, 12:58 PM - Thread Starter
Silent_Rage's Avatar
I am new on this site and hope that someone can help me with my problem. I have a explorer 8300hd+ pvr which I have owned for almost 2 years (i am a subscriber with videotron). The pvr has worked fine till last month . Now what has happened is that wether I am watching live or recorded shows there are constant freezes on the image and sound (only lasts a split second but is recurring). This does not happen on all my channels (the hd channels work fine). I have tried a regular hd box on my tv and every channel works fine. The signal strength varies between 3 to 7 dbmv the s/n is 37. I thought the internal hard drive was the problem so i switched it. However no luck the problem is still there! Can anyone help me with this problem (pvr is no longer under warranty). Thank you in advance for you help.
Silent_Rage is offline
Reply Digital Recorders (PVRs) General
