Time Warner HD DVRs are being wiped clean with system updates! - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Has TW remotely wiped your DVR?
Yes. 0 0%
Not yet. 1 33.33%
I hate TW. 2 66.67%
I am firing TW. 0 0%
If I had TW, I would fire them immediately. 0 0%
They should be sued and assessed punitive damages for this. 1 33.33%
Multiple Choice Poll. Voters: 3. You may not vote on this poll
post #1 of 5 Old 10-12-2011, 12:12 PM - Thread Starter
carysr's Avatar
Two weeks ago one of my DVRs lost 50 shows overnight. It had been only 65% full the night before and 5 regular def shows were scheduled to be recorded. The next morning, the only shows left were those I had set to never erase, and an 11 p.m. show. I called customer service & they said my DVR (SA 8300HD) must need replacing & set up an appointment. The service guy said maybe my TW DVR was dying, although it tested fine. He gave me a new DVR which means I lost the remaining shows. He said they were getting a lot of calls like mine but the others were caused by a TW software upgrade being sent to boxes. He said mine wasn't from that because mine happened the day before they started, & besides, my other DVR was still fine.
Then, exactly one week later, the same thing happened to my other DVR, only worse. This time it removed several (regular def) shows I had marked to keep as well as every show I hadn't marked. BTW, the "record log" on both sets shows that 10 p.m. shows were "not recorded because the set-top was off." (They were not.) They had recorded and erased 8:00 and 9:00pm shows. The Record logs said that the reason for all erasures was: "Deleted to make room for a new recording." Both DVRs showed only about 20% full afterwards. I called TW. The rep offered to send a repair man to look at it. I declined. She denied knowing anything about system wide erasures or software upgrades.
I called and ordered Verizon FIOS. Unfortunately I have to live with TWC for another 2 & 1/2 weeks. In the meantime, TW did it again Monday night to my second (original) box (exactly a week to the hour after the last time, & 2 weeks to the hour after the first time).
Is this happening to anybody else in SoCal (or elsewhere)?
carysr is offline
post #2 of 5 Old 06-21-2012, 08:38 AM
CWS
CWS's Avatar
I haven't checked in here in a while, but I'm curious about this post having absolutely no replies. The same thing has happened to me on Time Warner Cable, with an 8300HD box, and a different model prior box, several times in the past year.
I'll wager we aren't the only two affected.
CWS is offline
post #3 of 5 Old 11-26-2012, 10:01 AM
Tappintoes's Avatar
I came home the other night to a completely empty DVR box in my living room. It was about 80% full, which is normal, but I turned it on and there was nothing recorded and nothing even scheduled to record!!!! I was very upset as I had been saving something for years. I also have a box in my bedroom, but it wasn't affected by whatever happened to the living room box. Just tried calling TWC to ask what happened, but after 22 minutes of waiting for a rep, I hung up.
Tappintoes is offline
post #4 of 5 Old 06-04-2015, 11:12 AM
Demon665's Avatar
I know this is an old post, but I wanted to add my voice to those who have lost everything due to a Time Warner update. At least twice on two different 8300HDs.
Demon665 is offline
post #5 of 5 Old 06-04-2015, 07:49 PM
Dude111's Avatar
Quoted: 264 Post(s)
Liked: 402
Im sorry to hear that....
What if you keep your coax DISCONNECTED FROM THE DVR when your not watching it??
EDIT:
I suppose it would be wiped when you re-connect the wire! (Update applied then)
ANYWAY TO BLOCK THIER UPDATES??
Dude111 is offline
Reply Digital Recorders (PVRs) General
