Longer usb with hauppauge 1212 - AVS Forum | Home Theater Discussions And Reviews
Old 12-01-2011, 12:55 AM - Thread Starter
wthomas69's Avatar
Quoted: 12 Post(s)
Would like to use hauppauge 1212 hd dvr to record 360 gameplay on pc but the pc is about 20' from the 360/tv area, has anyone had any luck using a longer USB cable between dvr and pc than what comes with dvr, hauppauge does not recommend it on their web site
wthomas69 is offline
Old 12-01-2011, 07:29 AM
scoosdad's Avatar
I would use an active USB extension cable and not just a passive one. Something like this from Monoprice:
I just tested the connection between my 1212 and the PC using a similar cable I purchased from them about a year ago, made a short test recording at 1920 x 1080 and had no issues.
As long as the extension cable is rated for USB 2.0 you should be OK.
scoosdad is offline
Old 12-02-2011, 12:57 AM - Thread Starter
wthomas69's Avatar
Quoted: 12 Post(s)
Thanks for the advice, my other option was to put the pvr next to the pc and run 2 sets of 5 RCA component cables from 360 and back to tv
